Farmall Tractors Discussion Board
H water pump dissasembly. Flange removal problem.
Posted by The Red, John Fritz on March 27, 1999 at 14:16:25:
Well the good news is that this Dang Ol Farmall water pump is in pretty good shape. The bearings are excellent and I am putting in new oil seals.
As usual, the adjustable pulley flange is cracked and has been welded. I am trying to remove the outer flange and it is not budging. I looked at the parts book and it appears to be just pressed on. Any suggestions before I break this one??
Post a Followup
: Re: H water pump dissasembly. Flange removal problem.
