Farmall Tractors Discussion Board
Re: H water pump dissasembly. Flange removal problem.
Posted by Gene Kies on March 27, 1999 at 19:30:35:
In Reply to: H water pump dissasembly. Flange removal problem. posted by The Red, John Fritz on March 27, 1999 at 14:16:25:
John, there is a roll pin in the center of the pulley that must be removed first. Failer to do this will result in more peices than you'd care for. good luck, Gene
Post a Followup
: Re: Re: H water pump dissasembly. Flange removal problem.
