Farmall Tractors Discussion Board
Re: Auxillary Hydraulic Operation on 1943/44 Farmall H
Posted by Don on March 27, 1999 at 17:41:58:
In Reply to: Auxillary Hydraulic Operation on 1943/44 Farmall H posted by Walter E. Lohmann on March 27, 1999 at 17:33:26:
when the hydraulic lever is pulled back the plow shoud raise, when pushed forward the plow should drop. Hydraulic pump only works when the clutch is engaged.
Post a Followup
: Re: Re: Auxillary Hydraulic Operation on 1943/44 Farmall H
