Farmall Tractors Discussion Board
Re: Auxillary Hydraulic Operation on 1943/44 Farmall H
Posted by Red Blooded on March 28, 1999 at 16:08:28:
In Reply to: Auxillary Hydraulic Operation on 1943/44 Farmall H posted by Walter E. Lohmann on March 27, 1999 at 17:33:26:
There is a little stop on your rod that hits the support when you release the rod.This keeps your implements from dropping to the ground.Lift your rod up high enuogh to get through the hole and pusn it down The stop should go through the hole and your implement go down.Sometimes I haqve to give the one on my M a little extra shove to get it down but it should go down.
Post a Followup
: Re: Re: Auxillary Hydraulic Operation on 1943/44 Farmall H
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
