Farmall Tractors Discussion Board
Re: IH = H not firing on all
Posted by RK Smith on March 29, 1999 at 04:38:08:
In Reply to: IH = H not firing on all posted by Joe on March 28, 1999 at 18:18:12:
could be a small crack in the distributor cap, in the line to #3, and when cold it may be open and it will close when warm. Try putting a timing light on #3 wire when you first start engine. If no strobe in #3 only, then the problem is either the dist cap, plug wire, or plug. No compression problem will keep the plug from firing, it will only keep it from doing any good.
Post a Followup
: Re: Re: IH = H not firing on all
