Farmall Tractors Discussion Board
Re: Help on loose sleeve in the Dang Ol 1951 Farmall H
Posted by Skip on April 01, 1999 at 14:04:05:
In Reply to: Help on loose sleeve in the Dang Ol 1951 Farmall H posted by The Red, John Fritz on April 01, 1999 at 13:50:03:
Red, Do you have any projection of sleeve above the block, I&T says up to .006 if you do the gasket and head will seal it and hold it down. I would rather have them lose than too tight, I have seen them break and go down after startup when too tight.
Good luck , Skip
Post a Followup
: Re: Re: Help on loose sleeve in the Dang Ol 1951 Farmall H
