Farmall Tractors Discussion Board
Re: Torch Out a Cracked Sleeve?
Posted by Paul Fox on April 03, 1999 at 04:09:10:
In Reply to: Torch Out a Cracked Sleeve? posted by TMAC on April 02, 1999 at 20:46:10:
Had a similar problem on an F12 block. When the rod folded in half, it broke the sleeve off flush with the bottom of the water jacket.
I had read several times about welding a bead up the inside of the sleeve in two or three places and popping it out when the weld cooled and distorted the sleeve.
I tried it, and it worked slicker than snot. I did have to heat up the sleeve around the top and bottom seals with a torch, but then I only have a wire welder, so the beads didn't penetrate as much as they might have with a stick welder.
Try it, I think you'll be impressed.
Cutting the sleeve out leaves you with the chance of damaging the sealing surfaces if the torch blows through at the wrong time.
Post a Followup
: Re: Re: Torch Out a Cracked Sleeve?
