Sure: Use a switch that has three terminals on it. And two positions. 10 amp rating is OK with waterproof being very good. Run the wire from the F terminal on the Gen. to the center terminal. Run a wire from one of the others directly to ground (shiny bright metal) wire the other terminal to a 40 watt ceramic resistor of about 2.5 ohms or so, then to ground from there. The switch will control charge rate. Resistor side for low charge, Ground side for full charge rate. Run for less than 20 minutes on full rate, then switch to low rate. The resistor will get hot, so protect it from you, and other meltable things. An amp gauge is a good thing in this setup. as is checking for excessive heating and loss of water from the battery. This will duplicate what is in the light switch for the gen. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
