Re: charging by by passing the light switch
Posted by chad from michigan on March 17, 2009 at 19:14:33 from (67.142.164.33):
In Reply to: Re: charging by by passing the light switch posted by Janicholson on March 17, 2009 at 19:02:48:
I will be hooking it up with a amp gage.
So how is that done.
My question is both of the wires go to ground?
So there would be no wire going to the battery?
Its done your way because its positive ground?
Thanks
Chad
