Farmall Tractors Discussion Board
Re: Re: MD Low fuel pressure
Posted by Ronnie on April 03, 1999 at 20:24:15:
In Reply to: Re: MD Low fuel pressure posted by Clint Hofstetter on April 01, 1999 at 12:58:08:
I have a MD and other IH diesels, I would check for a crack in the line coming off fuel tank. If you need to bleed the fuel filters after losing fuel presure this could be your problem. You bleed the first filter without the engine runing and the other with it runing on gas. If your return to tank is good,I think your pump would be good.
Post a Followup
: Re: Re: Re: MD Low fuel pressure
