Farmall Tractors Discussion Board
Re: Re: H wont behave!
Posted by RK Smith on April 03, 1999 at 21:14:49:
In Reply to: Re: H wont behave! posted by RK Smith on April 03, 1999 at 20:32:23:
also, if the carb float was not set correctly, being too high with the gasoline level by gravity drain "above the level of the top of the main jet where it feeds into the venturi," you may be spilling excess gas over the main jet and into the air intake at low idle. This is because the main jet is not fully needed at low idle. Then, when you throttle up, the mixture is far too rich for a moment, until the mixture in the venturi returns to normal. The float level is set correctly when the gasoline is "primed" to the top of the main jet, but not spilling over. The carb kit had directions for the exact height for the float to be set. That could be the problem.
Post a Followup
: Re: Re: Re: H wont behave!
Today's Featured Article - Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the ... [Read Article]
