Farmall Tractors Discussion Board
Re: H wont behave!
Posted by RK Smith on April 04, 1999 at 06:59:40:
In Reply to: H wont behave! posted by Farmer John D. on April 03, 1999 at 16:47:35:
forgot to mention: Is your muffler stack in good condition and on the exhaust pipe when you are observing the problem? It should always be there if you suspect problems, because it was designed as one system. The engine "breaths" all the way from the air cleaner to the end of the raincap. The exhaust pipe and muffler stack are just extensions of the exhaust ports.
Post a Followup
: Re: Re: H wont behave!
