Farmall Tractors Discussion Board
Re: Update On Cracked, Stuck sleeve
Posted by Jim Becker on April 04, 1999 at 15:29:52:
In Reply to: Update On Cracked, Stuck sleeve posted by TMAC on April 03, 1999 at 18:39:05:
Don't get too carried away with the sledge hammer. If the crack was small enough to not be obvious on initial disassembly, it probably can be repaired. Old tractor blocks aren't that easy to find.
Post a Followup
: Re: Re: Update On Cracked, Stuck sleeve
