voltmeter setup
Posted by JeremyG on March 17, 2009 at 20:31:28 from (65.1.207.150):
I have a 46 Farmall A and I have put a single wire alt on it. I picked up a voltmeter at TSC have a question on the wire hookup. It has two studs on the back (one for positive and one for negative) and I understand that part. The positive stud connects from the wire from the alternator and the negative goes to the starter switch. But it also has a red wire and a white wire on the back of the voltmeter. What are those used for? Do they go to the light switch?
