Posted by charles todd on March 17, 2009 at 21:39:27 from (205.242.95.137):
In Reply to: voltmeter setup posted by JeremyG on March 17, 2009 at 20:31:28:
With a voltmeter you hook the positive to the ignition coil switched hot and the negative to ground (with a negative ground system). The reason for this is so when you shut off the key it turns off the voltmeter. If you do not have a key, like on a mag system, I suppose you could run it through an oil pressure switch. As for the "other wire" it is probably for a light bulb. It will be obvious if it has a light, it will be a wire out the center of the voltmeter. Wire the light to the headlights or dashlights.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
