Farmall Tractors Discussion Board
Re: Adjust carb and maybe governor?
Posted by RED Blooded on April 11, 1999 at 13:36:14:
In Reply to: Adjust carb and maybe governor? posted by Beginer Red on April 09, 1999 at 13:28:32:
You may also try the adjusting screw on the bottom of the acrb.This controls your fuel flow.Turn it all the way in then 5 turns out.Probably the gov. though.Replace the spring.Then go from there.
Post a Followup
: Re: Re: Adjust carb and maybe governor?
