Farmall Tractors Discussion Board
Adjust carb and maybe governor?
Posted by Beginer Red on April 09, 1999 at 13:28:32:
What is the correct procedure to set carb up on a 39 Farmall M? Does the governor need to be adjusted also? Any and all help is needed. Seem to run good but doesn't seem to have power. Unsure if the governor is opening up. It doesn't seem to.
Post a Followup
: Re: Adjust carb and maybe governor?
