Farmall Tractors Discussion Board
Re: IH 240 Utl Steering
Posted by Tom v on April 15, 1999 at 14:48:01:
In Reply to: IH 240 Utl Steering posted by Steve K on April 15, 1999 at 14:27:05:
Hi Steve: I have an IH-340 Utility with power steering. I also had steering problems, which, by the way, seems to be a common problem with these tractors. The BAD news is that you probably have excessive wear in the gears in your steering assembly (sorry about that). There is a "rack" on your power steering that is also probably worn pretty badly. You could try to take some of the "play" out of these gears through adjustments. Regarding the whining, make sure you have lubricant (should use Hy-Trans fluid) in the steering gear case - there is a plug (1/2") on the upper left casting that you should remove and check to see if it is full. Yesterday's tractors has Service Manual for about $55. Can't help you with the yellow paint. Email me if you would like further info.
Post a Followup
: Re: Re: IH 240 Utl Steering
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
