Farmall Tractors Discussion Board
Re: Cub vs. A
Posted by Daniel on April 15, 1999 at 19:02:56:
In Reply to: Cub vs. A posted by Putz-dad on April 15, 1999 at 16:34:14:
Everyone has there own opinion, but I would suggest a either Super A or 140. You get hydralic lift with these tractor which an A will not have. Also a Super A/140 will have more power than the Cub. Another thought is that the A and SA used sleeved cylinders which makes for an eaiser rebuild if the need arises and are overall a heaver duty tractor than the Cub. Depending on what implments you want to use be aware none of these tractors were factory with a three point lift and althought an after-market kit can be added, it will not be a true three point because there is no draft control. Hope this helps, Daniel.
Post a Followup
: Re: Re: Cub vs. A
