Re: 706 electrical problems-Help needed
Posted by Owen Aaland on March 18, 2009 at 18:35:47 from (65.165.246.54):
In Reply to: 706 electrical problems-Help needed posted by TJH72 on March 18, 2009 at 17:51:49:
If you are not getting poor quality rebuilt alternators, or have high electrical demand due to added accessories, the most likely problem is faulty wiring. Excess voltage will cause failure due to over heating. Those alternators will fail if run at maximum output for too long a period of time.
A poor connection can cause the regulator to demand maximum output from the alternator. Inspect the main wire from the solenoid battery post to the alternator output stud. Make sure that you do not have a poor connection between the connector and the wire. If that wire is good you should be boiling the batteries if the voltage is too high. Inspect the junction block and the wires going from the solenoid to the junction block, to the regulator. A poor connection there can cause low voltage at the regulator which again will cause the regulator to demand higher voltage.
With the system working you should not see more that 15 volts at the alternator output terminal, usually less than 14.5 volts. You should have no more than .1 volt drop across any connection. If you have .5 volt difference from the alternator output to the battery terminal on the regulator you are going to have problems.
