Farmall Tractors Discussion Board
Re: Gearlube / brake leaks
Posted by The Red. Yes there is a trick. on April 17, 1999 at 07:48:06:
In Reply to: Gearlube / brake leaks posted by Dick Davis on April 17, 1999 at 05:32:31:
Dick, Ken Updike clewed me in on this. Take a 3/8" drill bit and drill two holes in the seal. The seal chamber is about an inch deep. Then you can use a chisel to pound in and start the seal out. Then I used slip pliers to grab and pull the rest of the seal out. That old double seal is one assembly. I had mine out in 10 minutes each.
Be sure to install 2 seals per side and check the drum, where it slips into the seal, for smoothness.
Cannot tell you why your M seals lasted only one year. Did you put in 2 per side?
Post a Followup
: Re: Re: Gearlube / brake leaks
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
