Farmall Tractors Discussion Board
Gearlube / brake leaks
Posted by Dick Davis on April 17, 1999 at 05:32:31:
I have had very little luck getting a good seal between the transmission and the drum brakes on both an H and an M. I replaced the M's seals last winter and it is leaking now worse than before. The H I'm tearing down has what appears to be two seals installed and still leaks. Is the problem the shaft of the brake "rotator" (what is the correct term?) has developed wear grooves and cannot be sealed? What are some solutions for the leaks? Is there a trick to removing the old seal? Appreciate any help you smart guys can offer.
Post a Followup
: Re: Gearlube / brake leaks
