Farmall Tractors Discussion Board
Re: Removing coupler for H liftall pump. Any shortcuts??
Posted by Craig on April 17, 1999 at 17:58:56:
In Reply to: Removing coupler for H liftall pump. Any shortcuts?? posted by The Red, John Fritz on April 17, 1999 at 15:02:26:
I have two methods I use. I welded a square stock on an old socket to remove and instal couplers. But on the other hand when they really want to be stubborn I have a big heavy chisel gound flat on the end and hit it with a 4# hammer and this usually jars it loose.
Post a Followup
: Re: Re: Removing coupler for H liftall pump. Any shortcuts??
