Farmall Tractors Discussion Board
Re: Heating Problem with B
Posted by Craig on April 17, 1999 at 20:31:40:
In Reply to: Heating Problem with B posted by Carl Kurtz on April 17, 1999 at 19:25:48:
What are your symptoms that cause you to believe it is overheating?? I once worked on a Farmall B which was leaking out the rear of the block. The frost plug that is accesible by splitting the clutch housing from the engine was rusted through and leaking. At that time I discovered the cylinder block was full of all kinds of crud and stuff. Probably from the owner dumping in all sorts of radiator stop leak stuff during the last 30 years.
Post a Followup
: Re: Re: Heating Problem with B
