Farmall Tractors Discussion Board
Re: Deck removal
Posted by Clint Hofstetter on April 19, 1999 at 12:48:46:
In Reply to: Deck removal posted by Jerry Schill on April 19, 1999 at 04:12:08:
My son and I just put the deck back on his Farmall MD. I think the 400 deck would be very similar, with the exception of the shifter. I think if you have oil leak problems through the brakes you have a seal problem on the shafts the brakes connect to. I think the seals are accessible if you remove the brake housings and the brake assembly. However if the bearings are bad, the seals won't last long. I don't remember if the bearings can be replaced from the outside or through the top. I&T should tell you.
Post a Followup
: Re: Re: Deck removal
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
