Farmall Tractors Discussion Board
Farmall 2 cylinder
Posted by KdB on April 19, 1999 at 17:37:44:
I have an m that was seting for a good while before i got.It's been seting again now for 1 yr.It has no knocks& starts easy concidering, If was a deere it would sound good, I pulled wires off plugs 1 @ time. each changed the way it ran two more so. All 4 had good spark. Could I be lucky and it just be stuck valves.IT will run at full throttle or idle pops alittle when under a load like going up the hill "small hill" Ha Ha I'm no mechanic and i think i got took on this one! is there something i can add to gas or oil for the valves?
Post a Followup
: Re: Farmall 2 cylinder
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
