Farmall Tractors Discussion Board
Re: Farmall 2 cylinder
Posted by Stan(VA). on April 19, 1999 at 18:14:18:
In Reply to: Farmall 2 cylinder posted by KdB on April 19, 1999 at 17:37:44:
Run a compression check first. Then maybe pull the valve cover and verify rocker arm clearances and valve movement.
Stan(VA).
Post a Followup
: Re: Re: Farmall 2 cylinder
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
