Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Re: Oil Consumption
Posted by RK Smith on April 20, 1999 at 14:03:41:
In Reply to: Re: Re: Re: Re: Re: Oil Consumption posted by H Fan on April 20, 1999 at 12:01:24:
sounds like you're "hell bent for leather" to work on something. OK, have fun. This might give you some insight into the valve guides. Operate the H til warm, then at about 1,000 rpm, quickly throttle up to max. Observe for blue smoke. Now idle down to "dead" idle, barely running for about a minute at least, then throttle up to max. If you get a rush of blue smoke the second time, after the low idle period, but not much the first time, it may be a good sign of worn valve guides. At low idle, there is less neg pressure on the head and oil will collect over the valve guides. At higher rpm, the pressure increases and sucks the oil past the guides. At the higher beginning rpm, there is less pooling of oil, then less blue smoke at throttle up.
Post a Followup
: Re: Re: Re: Re: Re: Re: Re: Oil Consumption
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
