Farmall Tractors Discussion Board
Re: Farmall A - Got an eye on it
Posted by Mark on April 21, 1999 at 20:59:35:
In Reply to: Farmall A - Got an eye on it posted by Bill (Tx) on April 21, 1999 at 19:23:35:
My Farmall A had the similiar shifting problem, I took the cover off and the sliding gears were stuck on the shaft I oiled them and tapped them back and forth and it works fine. Not knowing how the engine is and why it was parked it might not be worth a whole lot. Is the drawbar on it, carburator, mag, original seat. How are the rims? Does it turn over? Was the exhaust covered when it was parked?
Was the block drained when it was parked? Most I have seen crack right behind the carburator. Just some things to check for.
Post a Followup
: Re: Re: Farmall A - Got an eye on it
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
