Re: Negative ground but with a generator???
Posted by CNKS on February 19, 2007 at 14:24:57 from (204.249.178.32):
In Reply to: Negative ground but with a generator??? posted by Alan in VA on February 19, 2007 at 13:22:14:
If your voltage regulator has stamped on it "6 volt positive ground", somewhere, I believe underneath, the contacts will burn faster, otherwise it makes no difference.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
