560D oil leak at oil cooler
Posted by garyiniowa on February 20, 2007 at 04:46:51 from (67.0.83.74):
I have a 560 Diesel it has developed a oil lead at what I think is the oil cooler, sitting on the tractor there is a oil leak on the left side of the motor inside the frame rail it has hoses running to it that appear to be cooling hoses from the cooling system, it looks to be bolted on with 2 3/8 studs is this the oil cooler and what does it take to put gaskets or O-rings in it? and do I have to take the engine loose and lift it up to remove the oil cooler? Thanks Gary
