Re: IH300 Utility hydraulics
Posted by Hugh MacKay on February 20, 2007 at 16:23:10 from (64.228.12.12):
In Reply to: Re: IH300 Utility hydraulics posted by Jack Crifasi on February 20, 2007 at 15:40:10:
Jack: Personally, I'd drain the system clean that screen and fill with new oil. Hydraulic pumps that have had oil in the system never need priming. That screen and oil are the economical fix, it may or may not work, however other possibilities are going to get expensive.
