Re: Oil leak on Farmall C
Posted by riverbend on February 20, 2007 at 19:24:01 from (208.160.33.20):
In Reply to: Oil leak on Farmall C posted by Vacherie on February 20, 2007 at 19:07:48:
If the oil is coming from above the plugs, you might need a new valve cover gasket. The head gasket is located below the spark plugs. When you do the next tune up and adjust the valves, replace the v/c gasket. When you have the cover off check to see that the oil drains are clear. In the mean time, just keep an eye on the oil level.
Greg
