Re: wierd science/ 10-20 pistons and sleeves
Posted by K-Mo on February 21, 2007 at 11:08:57 from (65.169.189.2):
In Reply to: wierd science/ 10-20 pistons and sleeves posted by russ hamm on February 21, 2007 at 05:37:16:
Don't have an answer and don't understand weird science but I had the same thing with a pair of loader cylinders. Once I forced the ram piston out of the cylinder, there was no way it was going back in. I took them to a hydraulic shop and they didn't understand it either. I ended up machining the the pistons down to get them back together. Worked fine ever since.
K-Mo
