Re: Help identifying PTO
Posted by JayWalt on February 21, 2007 at 13:50:37 from (70.226.20.153):
In Reply to: Help identifying PTO posted by JayWalt on February 21, 2007 at 12:44:06:
ok, got it. George, what would cause the gears to grind? Like If I try to put it in gear with the tractor FULLY STOPPED, sometimes it grinds them. It's bnot bad, if I ease into it, it will actually slow the gear down, almost like power is being tranfered through the clutch when its depressed. Could a throwout bearing thats not been lubed cause this? The clutch seems to be adjusted as good as it can be. just kinda wondered and wanted to take care of it if I could.
Thanks
