Re: Cu -v- Regular head gasket
Posted by Janicholson on February 23, 2007 at 06:34:09 from (199.17.6.122):
In Reply to: Cu -v- Regular head gasket posted by Tom Windsor on February 22, 2007 at 22:01:54:
Copper "gaskets" are primarily for containment of combustion pressures in modified engines. As Rusty indicates they also raise compression a bit. They are not the right stuff for general purpose repair as they are much less compliant to slight surface imperfections, and bolt tightness variations. More of a racing solution. They are very good when sealing extreme pressure, They also conduct heat very well. JimN
