Re: M Early Super M interchangeable parts?
Posted by CNKS on February 23, 2007 at 17:18:39 from (204.249.178.32):
In Reply to: M Early Super M interchangeable parts? posted by Bruce Shaver on February 23, 2007 at 14:06:59:
The M carb is jetted and adjusted different, but it should still work. The grille will have the holes for the Farmall emblem, rather than IH, and will not have the wide-spaced holes on either side that the Super M may or many not have. I suppose the mag will work as it was an option on the SM, distributer was standard, the advance curve may be different. As far as I know the hoods are identical.
