Re: why is my crack case filling?
Posted by Fromjb2 on February 24, 2007 at 08:23:17 from (74.101.67.211):
In Reply to: why is my crack case filling? posted by jack in acton ca on February 23, 2007 at 16:53:07:
Hi Jack, never worked on B275 but I think it is the same setup as B414D where there is a fuel pump on the right side of the engine block. This fuel pump has a diaphragm in it and it will crack over time or if there are any ice crystals from water in the fuel it will punch a hole in the diaphragm and cause Diesel fuel to leak into the crankcase.
A replacement diaphragm was available from CIH.
Good luck
JimB
