Would this work ?
Posted by Richard E. on February 24, 2007 at 12:31:15 from (67.72.98.45):
I have found a 504-utility/loader with a bad engine. I do have a Farmall "M" tractor that"s worn out with a good engine. Could I put this engine in the 504 ?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
