Re: IH 884 dsl hydraulics
Posted by Fromjb2 on February 24, 2007 at 20:44:43 from (74.101.67.211):
In Reply to: IH 884 dsl hydraulics posted by Ted Leigh on February 24, 2007 at 13:38:51:
Hi Ted, is this is a gear drive 884 not a Hydro correct? Does it have a T/A? If it is a gear drive with T/A it should go in any gear in LO T/A. HI T/A requires hydraulic oil from the return line from the oil cooler for the supply for the T/A pump. But LO T/A is mechanical srag clutch.
Has it warmed up to above freezing in PA yet?
Could be ice in the hydraulic filter?
Good luck
JimB
