Re: Farmall A No Start!
Posted by JayWalt on February 26, 2007 at 05:30:31 from (70.226.7.125):
In Reply to: Farmall A No Start! posted by plh_in on February 26, 2007 at 04:33:13:
if the starter went bad and pulled enough current to get the battery cables warm, or "hot" as you say, it is very likely that the solenoid contacts got burnt up. If you sent the solenoid with the starter, then I would think the shop would check the solenoid as well. If you didnt send the solenoid with it for rebuild, I would remove the solenoid, and hook it up to a 12v battery then check it with an ohm meter. anything above .5ohm I would replace it.
It is very likley that this is the problem. Double check all connections too. Did you jump the starter when u got it back to check to see if it turns over on the bench?
Today's Featured Article - History of the Field Marshall Tractor - by Anthony West. Any restorer who has some knowledge of turn of the century farm machinery, will recognize the name Lanz Bulldog!! This machine was to say the least unusual in its appearance. The huge flywheel and coffee percolator shaped exhaust. Along with square body lines and cylinder head protruding forward of the front axle. Would become the visual differentiation that people would quote to separate the Lanz from other period machines. The Marshall company based at the Briannia Works in Gainsborough ... [Read Article]
