Re: Farmall A No Start!
Posted by Janicholson on February 26, 2007 at 20:08:42 from (66.173.50.163):
In Reply to: Re: Farmall A No Start! posted by JayWalt on February 26, 2007 at 11:58:16:
You might get by with a six volt solenoid for a whle, but it is sensitive to a greater extent than the starter. Ford early sixties solenoids are cheap. JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
