Re: Farmall A No Start!
Posted by JayWalt on February 26, 2007 at 11:58:16 from (70.226.7.125):
In Reply to: Re: Farmall A No Start! posted by Roger Mills on February 26, 2007 at 07:49:35:
hmmm, not to hijack the thread, but im in the middle of a 12v conversion. Does the solenoid need to be changed to a 12v one? I kinda hope not or that means I have to spend more $$$
All the solenoids I got are laying around from gm starters and they have the bendix linkage built in and would look godaweful if I tried to cob one of those on the side of the starter. Dad might have a ford solenoid laying around.
I would imagine that the short duration to start the tractor would not hurt the solenoid, but sometimes these things can be tempermental about volatges, and I sure as heck dont wanna burn up the original, as I'd like to keep it If I have to replace it with a 12v one, so the next owner can convert back to 6v if they want.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
