Re: Farmall A vs Super A Head Gasket
Posted by Hugh MacKay on February 27, 2007 at 02:34:57 from (216.208.58.155):
In Reply to: Re: Farmall A vs Super A Head Gasket posted by Janicholson on February 26, 2007 at 20:39:25:
Jim: I quite agree with you, don't know as I've heard of actual cracking. I've heard numerous examples of 1 or 2 cylinders failing prematurely, and the blame got put on wrong head gasket for the application. If my recall is correct, there has been more problem with the gasket intended for water pump application, going in a thermosyphon tractor, although I've heard both.
