Re: fouling advice
Posted by Janicholson on February 27, 2007 at 06:08:35 from (199.17.6.122):
In Reply to: fouling advice posted by karl f on February 26, 2007 at 21:26:51:
A worn valve guide will allow excessive consumption on one cyl. The other Ideas are possible as well. Stuck rings on one cylinder will also be similar. As often recommends, put an ounce of auto trans fluid in that cylinder for several days, then pull the plug out and spin the starter to clear the cylinder of excess oil. The ATF can assist tn the freeing of stuck rings. (it is cheap and non invasive) Running a hotter plug is OK if the engine is not used for continuous full power operation. They are a source of pre ignition in loaded operations at full operating temp. JimN
