Re: hydraulic problem
Posted by JayWalt on February 27, 2007 at 22:43:05 from (70.226.7.125):
In Reply to: hydraulic problem posted by Don Benson on February 27, 2007 at 15:50:27:
The lower port is the res dump port, it flows right into the resevoir. The upper larger port is the pump pressure line. The smaller port is the regulator line. The system works as follows... Pressure is fed into the regulator lines and acts on the safety vavle. when the safety valve sees full pressure in this line, it dumps the pump pressure into the resevoir. The system runs between 30 and 60 lbs this way. As soon as any movement is done to the valve, it creates a pressure drop through the regulator line and when the safety valve sees this, it causes the pump to instanlty build up pressure to the control valves. This is a hard process to describe without illustrations. I thoerize that if you cap the small port, and use the bottom port as a dump, and the top large port as the pump feed to open center control vavles, that it should work. The documentation I have here doesnt specifically say what the ports are or how they interact between the front and rear set.. However, all of the pressure control is done via the safety vavle, and removing it and using it as I said should work unless I have overlooked something. The ports on the resevoir should be NPT holes and should readily except fittings. If you do that, I would advise smearing some thick grease on the oring lands afterwards so they dont get corroded in case someone in the future wants to convert back. I believe if you have one hydratouch control valve which you want to keep, if you mount it on the safety valve and do as I said above that the system will also work. I really meant to map out the ports when I had the res cover off of mine, as that would give me a more definite answer for you. I can scan the 18 page hydraulic manual. It is not EXACT to the 300u (it is for the farmall 300 and 400 series which are pretty much the same design wise), but the system is basically the same and has taught me alot. I wish I could be of a more definite help.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
