D179 injector leak
Posted by Marc Hudson on February 28, 2007 at 13:31:51 from (140.142.107.131):
Hi all,
I have a D179 engine (in a IHC 454) the appears to be leaking fuel at the #3 injector. Is there a gasket between the injector and the engine block that can leak? I can't seem to be able to tell exactly where the fuel is leaking from with the engine fan blowing air all over. Any ideas?
Thanks for your input.
