Re: D179 injector leak
Posted by Fromjb2 on February 28, 2007 at 18:32:36 from (74.101.67.211):
In Reply to: D179 injector leak posted by Marc Hudson on February 28, 2007 at 13:31:51:
Hi Marc, check the return line (metal braided line) on top of the injectors. Sometimes they leak in cold weather and until the engine warms up. Have replaced a couple times on our 454 over the last 30+ years. If you change the return line be careful not to drop the small brass washers that go on top and bottom of banjo fitting.
JimB
