Re: H farmall tires help
Posted by Wardner on February 28, 2007 at 14:25:40 from (4.154.247.14):
In Reply to: Re: H farmall tires help posted by ARF on February 28, 2007 at 12:33:13:
The name of the game in snowplowing is narrow tires. It all relates to ground pressure. That's why the old Oshlosh and Walters used four tires instead of six.
Only if you are using chains will the bigger tires be a benefit. Even then you will need some ballast to increase the ground pressure so the chains will bite.
