Re: 404 or 444 Crank ??
Posted by El Toro on March 01, 2007 at 13:40:29 from (205.188.116.133):
In Reply to: Re: 404 or 444 Crank ?? posted by VinnyJimbo on March 01, 2007 at 12:55:46:
The Farmall M had the same situation, they had
2.7474"-2.7485" on the crankshaft main jouranal
up until S/N 278049 and on the rods 2.4975-2.4985".
From S/N 278050 and up the shaft measured 2.8075-2.8085" on the mains and the rod journals meassured 2.5475"-2.5485". Hal
